Front crank seal- Is this going to leak?
Just installed a new front crank seal while I've got the engine out for broken head stud.
Pushed it in with a PVC cap fitting and didn't see that the rubber outer part of the seal got hung up on the edge of the case indent. Not pretty..is this going to leak?? ![]()
1978 SC coupe #1834 |
yes it will probably leak. they dont cost much. But pulling the engine and taking it apart to replace the seal will be a huge pain.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
abit off center
Was the old seal leaking or was it leaking around the bearing O-ring? That seal looks to be all the way in and square.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
yes in and square but the outer rim is torn
That will probably leak, the seal is all deformed now, and is probably not putting even pressure on the seal lip itself. For the 10 bucks the seal costs, and an extra day wait, I would not take a chance.
No left turn un stoned |
Ordered...Thanks for all comments.
Super Moderator
BTW, I suggest installing the seal dry, or with a minimal coat of oil on it (It looks liek you've got some goop on there?) . Many of the non-hardening sealants can allow the seal to push back out later on as it acts like a permanent lube.
A few years ago we (Souk and I?) were finishing up an engine, installed both seals with something like Curil-T and were sitting back and having a beer admiring the handywork. 15 minutes later both seals went "POP" and came right out.
Somewhere in the Midwest
![]() Time to build another engine in the spring, Chris. (evil grin) |
leak
Before installing the new seal, take the sharp edge off of that area with a small file or knife etc.. or it will do it again
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Thanks all...3rd time was the charm.
