camshaft?
Camshaft ?
How can I verify the grind of a camshaft?Why are the lobes on the left more L spread on the shaft while the lobes on the right shaft are more rabbit eared.
Jeff
Old 12-19-2011, 10:24 AM
If you dont believe what you have, check the back end for stampings like WEB then some numbers like 561/561 then call Web cam and the secretary will tell you what the grind is.
Same with Elgin.
The casting numbers on the side will tell you what the cam is in the other reference by Tom on the next question above or below this question.
Bruce
Old 12-20-2011, 06:37 PM
