Judging from the look of the sealing surfaces and blow by on most of the cyl the studs broke after the engine was sitting.
Bruce |
The heat needed is not for "expansion" of the case, its to break the loctite. With broken studs welding on a nut works great and the heat from welding is enough to break the loctite. Then an impact gun (cheap electric works fine) on the nut. |
It's on the road
http://forums.pelicanparts.com/uploa...1339357089.jpg
http://forums.pelicanparts.com/uploa...1339357116.jpg http://forums.pelicanparts.com/uploa...1339357181.jpg http://forums.pelicanparts.com/uploa...1339357067.jpg It' done and on the road, i will get a tag and register this week, a few things to fix but very road worthy. FYI this is the build sheethttp://forums.pelicanparts.com/uploa...1339357936.jpg |
not bad, oh, by the way, your labor-priceless!
| All times are GMT -8. The time now is 05:19 AM. |
