-   -   Cam sproket offset question please (http://forums.pelicanparts.com/911-engine-rebuilding-forum/648213-cam-sproket-offset-question-please.html)
berni29 01-01-2012 09:51 AM
Hi There
I am just putting my cam housings and sprokets back on my 993, and I am at the point of working out my offsets.
I have 8.30mm between the crankase face and the end of the layshaft. I have 48.25mm between the crankcase face and the right hand cam sproket face (lefthand not on yet).
I do not know what the distance is between the end of the layshaft and the hidden face of the sproket in there is.
Can anyone please help me with the calculation I have to make? I have looked through the forum but could not find the figures.
Many thanks in advance
Berni
Flat6pac 01-01-2012 12:30 PM
With the 8.3 mm figured in I believe, off the top of my head, to be 51mm.
Bruce
Bentley Spec for a 964 same case as 993
left 98.07 +/- .25mm+ your 8.3
right 43.27 +/- .25mm+ your 8.3
To the outside front surface
My 51mm was close
berni29 01-01-2012 02:07 PM
Hi
Thank you very much. I found the section in the workshop manual just now. I really must look more carefully next time.....
Tks again
Berni
