-   -   back fire (http://forums.pelicanparts.com/911-engine-rebuilding-forum/648414-back-fire.html)
den912 01-02-2012 09:46 AM
back fire
my 2.2 back fires a bit if the compression is bad whats the solution also the gear stick seems very floppy i,m not mechanically mined at all and i,m hoping to put the car into a garage but would like to understand a bit more before i do this.one other thing some thing seems to be stuck as revs higher than it use too thanks brian
