-   -   back fire (http://forums.pelicanparts.com/911-engine-rebuilding-forum/648417-back-fire.html)
den912 01-02-2012 11:03 AM
back fire
my 2.2 seems to backfire and pop a bit the distributor and leads seem to be fine I think, can this be down to low compression? If so what does it take to fix this? Is it a big job to fix?
Flat6pac 01-02-2012 01:12 PM
The backfire through the carbs is indictative of lean running or bad cam timing.
Bruce
GrantG 01-02-2012 02:46 PM
Are you using MFI? If so, maybe your fuel-shutoff function is not working properly (the one triggered by the microswitch when throttle returns to idle position, but revs are still above idle).
tom1394racing 01-02-2012 03:31 PM
Backfire at partial throttle with carbs is often caused by plugged idle jets.
I ran my tank too low the other day and they plugged with moisture. Pulled them out, blew them out with compressed air. Problem solved.
