-   -   Unreachable nut on cylinder 6 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/648699-unreachable-nut-cylinder-6-a.html)
heathbar 01-03-2012 04:45 PM
This seems like a simple problem, but I cannot reach the last nut on the intake manifold flange on cylinder 6...I'm trying to remove the fuel injection system on an '82 Targa. I've tried ridiculous numbers of sockets and wrenches, and inevitably, if I can get a socket on there, I have too much articulation from all the wobbles to actually apply any torque. Any suggestions??? See pics! Thanks
http://forums.pelicanparts.com/support/smileys/wat5.gif
http://forums.pelicanparts.com/uploa...1325637751.jpg
http://forums.pelicanparts.com/uploa...1325637770.jpg
Flat6pac 01-03-2012 05:10 PM
I use am 18 inch extension 1/4 inch with a swivel 12mm from Sears, gets them all.
Bruce
Two Rivers 01-05-2012 04:41 AM
Why not just remove whats in your way?
arbita1 01-06-2012 09:34 AM
I'm pretty sure I got them all off with a 3/8" socket and universal on a 6" extension. You have to try different angles sometimes.
boyt911sc 01-06-2012 10:00 AM
Use swivel sockets.......
Like what Bruce suggested, use the correct tool. I have an assortment of swivel sockets from Sears Hardware and have been removing these CIS compoments for years with ease. Use a swivel socket with a 6" extension and you could remove/install all the intake runners in minutes.
Tony
cmcfaul 01-06-2012 11:19 AM
What I think everyone is saying, just to be clear, is not adding a socket to a universal. Sears sells specific sockets with universal permanently attached so they are nice and small. The perfect tool for the job. Just connect it to a nice long extention and you will be good to go.
Chris
73 911 E
heathbar 01-06-2012 02:00 PM
Thanks everybody, I'll give the extension and swivel socket a go!
