Wrightwood 964 Gasket ID help
I purchased a Wrightwood Racing lower end gasket kit. Some of the seals and washers are very obvious where they go. Others not so much. I was wondering if anyone could help Id the washers and gaskets in this picture?
![]() TIA!!
1981 911sc RoW Coupe (forever under 3.6L conversion) 2003 996TT Basalt black |
Case breather
thermostat, intermediate shaft cover, Im thinking on the steering pump? oil pump safety locks, assorted washers for the magnet drain, the chain rail bolts, steel washers to go with the prevailing torque nuts green cross bolt seals, at least 24 to do the job. where is the oil pump seals? Bruce |
