-   -   Intermediate shaft compatibility. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/652711-intermediate-shaft-compatibility.html)
faverymi 01-21-2012 01:02 PM
Hi there!
Finally getting all the parts to assemble my very first 2.7 engine.
My 7R case came with intermediate shaft gear#
901 105 235 1R size 0. it is worn.
I can only find
930 105 136 0R size 0.
They look the same with my rudimentary tools measure the same and both fit.
Can I just replace them? Should I worry? Do you need pics?
Thank you, Felipe
faverymi 01-21-2012 01:06 PM
Pelican only sells one kind and only has year specs 74 to 89.
thank you for the help. F.
faverymi 01-24-2012 06:47 PM
Bump for an answer.
Thanks.
turbo nut 01-24-2012 10:23 PM
What works well is a 964 I-shaft steel gear with the matching crank gear.
faverymi 01-25-2012 05:19 PM
thank you for the answer but....
Im trying to minimize changes to have less variables on my build.
This is my first 911 engine and Im hoping I can get it right.
I will take some pics thanks again and bump.
AlfonsoR 01-26-2012 05:35 PM
You may want to contact a professional engine builder like Steve Weiner or perhaps JB Racing. JB Racing makes a straight cut gear set, and although you may not be interested in a new set, they maybe able to answer your questions. JB Racing - Porsche Engine Components
Getting the gear set right is pretty important, meaning if you don't get it right, it may mean your engine grenades in a short while. That's a lot of money to risk for most of us, not to mention time, plus having to clean out oil lines/coolers/ tank if metals start to flow through your oil system. You may want to pay a small consulting fee to get this right. Just my 2 cents.
faverymi 02-04-2012 06:26 PM
I followed AlfonsoR advice and went to the machine shop here in MA
Gears were measured properly and they are the same.http://forums.pelicanparts.com/uploa...1328408702.jpg
here is a pic from 911 SC with the part number.
Size 0
faverymi 02-04-2012 06:28 PM
Here is a pic from the old one on the 7R 2.7 case.
http://forums.pelicanparts.com/uploa...1328408856.jpg
the part number is there.
also size 0
faverymi 02-04-2012 06:31 PM
I also had another pelican PM me confirming the info.
Early and late aluminum gears are interchangeable as long as they are the same size.
Thank you everybody!!!
Now time to start assembling.
