new manifolds needed, source?
On MY 71 T I'm putting old 2.5 parts on new 2.7 rebuild. 2.7 is a 75 S with 8,5 nickies, usualy updates. From blown 2.5 I'm adding E cams, ssi, stock muff with internal mods. Since my intake manifolds are from 2.2 T zenith and on 32 mm intake heads and I'm now going to 35 mm intake 2.7 heads do I need to worry ablut better intake manifolds? which distributer should I use? any other problems ? and sorry to have cross posted. Thanks Henry
Old 02-24-2012, 01:08 PM
ASE Master Tech - 35 yrs
larrym's Avatar
you should either buy PMO manifiolds that match the 2.7 port size (i did that)
- or find somebody with experience & a flow bench for matching the old manifolds
the PMO manifolds are taller, btw; ostensibly can develop better flow
- just have your 2.7 distributor recurved - try Rennsport Systems for that work
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-26-2012, 11:15 AM
