930 cam housing for a 3.0 SC engine?
I tried a search on this with no luck. Can I use 930 cam housing on my SC rebuild? The 930 part number is 930.105.111. I do not have access to SC part number at the moment.
Thanks, Lee |
They are all the same carriers. 4 bearing carriers, 930 part numbers are sized for the size of the bearings on the cams where the older 3 bearing are smaller holes on the carrier and smaller bearing on the cams.
Bruce |
| All times are GMT -8. The time now is 12:27 AM. |
