Brando
quattrorunner's Avatar
Rocker shaft walking
I almost hate to ask this, but what about RTV?
I have a problem that I'm not sure about yet, maybe my housing is damaged or my rocker is just not tight enough. But I've had a rocker shaft move out and allow the rocker free. Twice! Yeah.....
This engine is new, the rockers didn't get resurfaced as I thought a low mileage engine(50000 miles) didn't need it and the tolerances "seemed" great(very tight).
Well, I'm going to get the rocker shaft seals from turbokraft, but they're back-ordered and I want to run again.
What opinions or pointers do any of you guys/gals have for me?
Thanks BA
Turbo powa!
1977 911s. it's cool
Old 01-27-2012, 09:36 AM
MBEngineering's Avatar
HI BA
have a look hear;
TurboKraft : Catalog Home : Rocker Shaft Lock Set [901 105 360 TK] - $359.00
might just sort out you rocker shafts on the move?
regards mike
Old 01-27-2012, 10:17 AM
Brando
I menat to say rocker shaft locks not seals. Theyre backordered.
I intend to buy them
Turbo powa!
Old 01-27-2012, 10:51 AM
You need 18 lbs. of torque on the shafts. Getting a torque wrench in a installed engine is almost impossible without a special tools. When tightening these by hand they need to be very, very tight, if that makes any since, to me thats what 18 lbs. will feel like with allen wrenches. Hopefully the shaft hasn't spun and worn the tower, probably not.
Check here for tips
"Competition Engineering - CE's war on oil leaks"
Old 01-27-2012, 12:06 PM
Brando
Wow that is a relief actually. Because I built the engine and I have felt like a real chum because of some oil leaks and this rocker issue. Thanks for that link 4sd911.
Turbo powa!
Old 01-27-2012, 12:16 PM
abit off center
cgarr's Avatar
I like to oil the end caps a bit since they have to wedge in the shaft to expand it.
______________________
Craig
G2Performance
Old 01-27-2012, 12:19 PM
