-   -   2.7 compression (http://forums.pelicanparts.com/911-engine-rebuilding-forum/654474-2-7-compression.html)
tassie targa 76 01-30-2012 12:46 AM
2.7 compression
G'Day All
just did a cold compression test of my 2.7
i dont have much history on the car other than it has been rebuilt some time in the past
i runs well revs well no smoke seems generally good all round
im about to remove the engine and transmission and everything else for a full body restore thats where my money is going at this stage
anyway back to cold compression i got approx 100psi + - 5 across all 6
not sure if this means a top end pull down any thoughts
Regards Michael
http://forums.pelicanparts.com/uploa...1327913202.jpg
Flat6pac 01-30-2012 04:23 AM
First off, it apears you have the wrong coil in place. With a CD box, you require a Bosch 001.
When you warm up and seal you should have 145# or slightly better. The 100# cold with the +/-5 is good all around for cold as there is enough compression for ignition.
Bruce
tassie targa 76 01-30-2012 11:57 PM
coil
yes i have been told about the coil i will be replacing the ignition system during overhaul.
are you suggesting that simply by bringing up to operating temp an increase of up to 45psi
i was also told that doing a cold compression test with kj intact reduces the air flow therefore reducing overall outcome.
does that sound right
regards michael
911pcars 01-31-2012 10:49 AM
Bruce
Could be the cranking speed is lower than normal or the engine is tired (worn rings).
Squirt a teaspoon of oil into each cylinder and retest. If the compression increases close to normal, I'd suspect the rings.
Sherwood
larrym 02-18-2012 01:15 PM
my 2.7 with 8.5 CR pumps 150 cold (6 bumps) - and hits 75 on the first bump at 60*F
my 2.8 with 10.5 CR pumped 175 with 75 on first bump at 70*F
tassie targa 76 02-19-2012 06:38 PM
i suspect a set of ring are in order hopefully not much else as all my money is going on body at this stage
tom1394racing 02-20-2012 03:02 AM
Make sure you have the throttle fully open when doing the compression test.
A closed or partially closed throttle will depress the readings.
