-   -   Timing chain issue (http://forums.pelicanparts.com/911-engine-rebuilding-forum/654599-timing-chain-issue.html)
ONQRACIng 01-30-2012 11:18 AM
Timing chain issue
New build, 3.0 case, GT3 Crank, Elgine Cams. We have the case up to cams, and I just measured the spockets, Left reads 3.88 inch and right is perfect at 1.70 (per bently). Everthing looks good, but the right chain seems to "click" or bind on the sprocket. These are used sprockets, dont seem worn. I have Stomski Mech tensioners, and have them tight. Any ideas?
TIA
ONQRACIng 01-30-2012 03:00 PM
got it
Flat6pac 01-30-2012 04:17 PM
What was it??
ONQRACIng 01-30-2012 05:37 PM
Turns out, even though I was in spec for the right dimension, I was .020 off form the actual distance from int. shaft gear to face of the sprocket. Removed a shim, and all is well.. Running 4 shims on the left, and 2 on the right.. Now onto the timing of the cams. Should be ready for Motec by Friday.
911pcars 01-31-2012 10:51 AM
Mechanical tensioners = track engine, yes?
Factory tensioners recommended for street-based engines.
S
ONQRACIng 01-31-2012 11:29 AM
Yes, full track 3.6. We always run the Mechanical tensioners in our race engines.
