-   -   Camshaft options for twin plugged 3.4L Motronic (http://forums.pelicanparts.com/911-engine-rebuilding-forum/655175-camshaft-options-twin-plugged-3-4l-motronic.html)
polizei 02-01-2012 06:43 PM
Guys,
I'm rebuilding my 3.2L Carrera into a reliable, street performance car. I'm sticking with Motronic for now but building so that I can go Carbs or ITBs down the road, with the understanding that I'll need to change camshafts when I do make that move.
I realize Motronic limits my camshaft options, but I'd like to what my options are. My goal is a reliable street rod that's also fun to drive at DE events. I've read that 964, 993ss (Daugherty) and Webcams 20/21 are popular options. How will these cams vary? Any other options I should consider?
Here's my build sheet:
Carrera Crank/Oil Pump/Case
Reconditioned/Balanced Carrera rods with ARP rod bolts
Mahle P&Cs - 98mm bore with 10.4:1 static compression - "RSR" - Hemi-shaped dome with double valve reliefs
Supertec Head Studs
Supertec-Rebuilt Cylinder Heads - twin plugged - titanium springs/retainers
964/993 twin plug distributor
Motronic Induction System with Andial Splitter
J&S Safeguard to handle knock
Steve Wong custom chip
993 Heat Exchangers with Flowmaster muffler
Thanks for your input.
cgarr 02-01-2012 07:15 PM
That is the exact setup I have: I used his super cup cams from camgrinder.
Henry Schmidt 02-01-2012 09:10 PM
Nice choice for the build.
polizei 02-02-2012 05:18 AM
Craig - What's the power delivery like on the super cup cams?
cgarr 02-02-2012 05:35 AM
The original setting of 2.0mm overlap gave very good low end but less at 7k. John said to set it at 1.6mm and it keeps pulling up to 7k without a problem. Very nice engine. Mostly street but some track.
polizei 02-02-2012 05:45 AM
Do you know how these super cup cams compare to 3.2L carrera cams? Ideally, I'd like a cam that could pull strong up to 6500RPM and still be fun on the street.
That's what I'm going for :)
polizei 02-02-2012 02:04 PM
Emissions are not a concern, by the way.
polizei 02-02-2012 06:59 PM
It looks like the DC20, 993 Super Cup and 964 Super C2s are about the hottest cam I can reliably run on a street car having pistons with valve reliefs. Do any of these seem particularly well-suited for my setup?
