Camshaft options for twin plugged 3.4L Motronic
Guys,
I'm rebuilding my 3.2L Carrera into a reliable, street performance car. I'm sticking with Motronic for now but building so that I can go Carbs or ITBs down the road, with the understanding that I'll need to change camshafts when I do make that move. I realize Motronic limits my camshaft options, but I'd like to what my options are. My goal is a reliable street rod that's also fun to drive at DE events. I've read that 964, 993ss (Daugherty) and Webcams 20/21 are popular options. How will these cams vary? Any other options I should consider? Here's my build sheet: Carrera Crank/Oil Pump/Case Reconditioned/Balanced Carrera rods with ARP rod bolts Mahle P&Cs - 98mm bore with 10.4:1 static compression - "RSR" - Hemi-shaped dome with double valve reliefs Supertec Head Studs Supertec-Rebuilt Cylinder Heads - twin plugged - titanium springs/retainers 964/993 twin plug distributor Motronic Induction System with Andial Splitter J&S Safeguard to handle knock Steve Wong custom chip 993 Heat Exchangers with Flowmaster muffler Thanks for your input.
Andy - 1987 911 Carrera Coupe |
abit off center
That is the exact setup I have: I used his super cup cams from camgrinder.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Try not, Do or Do not
Nice choice for the build.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Craig - What's the power delivery like on the super cup cams?
abit off center
The original setting of 2.0mm overlap gave very good low end but less at 7k. John said to set it at 1.6mm and it keeps pulling up to 7k without a problem. Very nice engine. Mostly street but some track.
That's what I'm going for
Emissions are not a concern, by the way.
It looks like the DC20, 993 Super Cup and 964 Super C2s are about the hottest cam I can reliably run on a street car having pistons with valve reliefs. Do any of these seem particularly well-suited for my setup?
