-   -   Seal Install Damage? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/655191-seal-install-damage.html)
NoEardGoat 02-01-2012 08:35 PM
Did I just damage this seal installing it into the No. 8 nose bearing?
Or is it common and OK that some of the rubber ribs caught and cut on the outer surface?
http://forums.pelicanparts.com/uploa...1328157318.jpg
Henry Schmidt 02-01-2012 09:04 PM
It's very common. The install is not perfect but you should be fine.
Next time use Dow o-ring lubricant on the outside of the seal.
JJ 911SC 02-02-2012 02:29 AM
If it worry you and will second guess yourself until the rebuild is finish, $15 for a new one is a good investment :)
