Turbo Scavenge Pump
Figure its worth opening it up to make sure there isn't anything wacky going on in there... can't seem to find a source for the internal seal and/or any other parts that should be replaced while in there. Suggestions would be much appreciated.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 02-13-2012, 10:52 PM
pump
There are none, Its an inspection,detail and reassembly
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-14-2012, 05:46 AM
