-   -   68 re rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/658902-68-re-rebuild.html)
tepps 02-17-2012 05:26 PM
68 re rebuild
I am putting the heads, and cam towers on my 68 rebuild.. The previous set of allen head bolts has gone missing courtesy of Motor Messer. I am left with 24 grade 8 15 mm head with locking washer base nuts. They are probably zinc as they show no signs of rust or corrosion... Do I use these or try to source the OE allen nuts????. Tepps.
tom1394racing 02-18-2012 06:09 AM
There are 3 locations on each cam tower where you need to use the Allen nuts to clean the cam tower.
Send me you shipping address if you would like (6) of them.
tepps 02-18-2012 09:38 AM
nuts
Tom ,I have the 6 allen nuts for cam towers, I am talking about the 24 cylinder head nuts.My shipping address is 2365 south park ave. Buffalo Ny 14220
tom1394racing 02-18-2012 10:38 AM
Hex nuts can work for the head studs. Just make sure you have enough clearance to get a socket in there.
