-   -   does this look normal...part two (http://forums.pelicanparts.com/911-engine-rebuilding-forum/659346-does-look-normal-part-two.html)
jimtweet 02-19-2012 02:13 PM
sorry here was part one,
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/658163-does-look-normal-timing-chain-tensioners.html
this is the other side, i just ordered locking collars, but dont know how this side is going to fit...
http://forums.pelicanparts.com/uploa...1329689400.jpg
Flat6pac 02-19-2012 05:36 PM
Lock the collar as high as you can get it on that tensoiner.
Bruce
jimtweet 02-20-2012 06:45 AM
Bruce
thats the issue i see, there is no room to even get the collar on:confused:, and timing chain seems to be pretty tight on this side, tighter then passenger side
Flat6pac 02-20-2012 10:34 AM
Sometimes its that way. Turn it over a couple times and see if you ve got a link doubled. Check and make sure your chain rails are bolted properly. If one of the bolts you cant see is under the rail you ll be too short too.
Bruce
