-   -   Prove to me that it's possable to (http://forums.pelicanparts.com/911-engine-rebuilding-forum/662716-prove-me-its-possable.html)
quattrorunner 03-03-2012 12:39 PM
Install rsr shaft seals without shearing them off using the dry method. I feel it's still better that without them but I'm completely confused how you can do it with engine in car.
HFR_Racer 03-03-2012 04:47 PM
Why install them dry in the first place? I installed mine oiled and I'm not having an issue. I thought that oiling them was the correct method actually.
quattrorunner 03-03-2012 04:58 PM
I've been told its the way. Not sure about that with rsr though.
afterburn 549 03-05-2012 07:11 AM
use a dab of your flavorit lube...I used silicone..not the type that sets up..
KTL 03-07-2012 08:17 AM
I agree with the silicone treatment. It's good practice to use this goop. Because it not only lubricates the seal but adds additional protection from oil aging. The silicone paste is oil and solvent resistant, so it stands the test of time quite well.
Henry Schmidt 03-08-2012 02:54 PM
We use Dow 55 Silicone Lubricant on all o-rings on air cooled engines.
The commercial product is Dow Corning 111
http://forums.pelicanparts.com/uploa...1331247273.jpg
