Mechanical chain tensioner and parts for oil by pass mod
Hi,
I rebuilt my 66 engine and would like to know : - what Mechanical chain tensioners, chain wheel support ... I should install to improve reliability - what are parts # (piston, spring, plug ...) I have to change when oil by pass mod is done. I use chain box year 66 and 68 - 73 camshaft housings, Carrera oil pump mod by Supertec Here is what I have found on PP forum but would like to be sure before order. Thank you. 1 - Timing parts : Chain tensioners ... Right side : - chain tensioner # 930 105 053 00 - axle support for chain tensioner if used # 901 105 056 01 M100 - chain wheel support from 1980 # 930 105 510 00 or early chain wheel support modified by Supertec or early chain wheel support + chain wheel spacer # 930 105 513 00 - sprocket # 901 105 055 00 - sprocket axle # 901 105 056 01 Left side : - chain tensioner # 930 105 053 00 - axle support for chain tensioner if used # 901 105 056 01 M100 - chain wheel support from 1980 # 930 105 509 00 or early chain wheel support modified by Supertec or early chain wheel support + chain wheel spacer # 930 105 513 00 - sprocket # 901 105 055 00 - sprocket axle # 901 105 056 01 Chain tensioner slip prevention collars can be fitted on #901 and 930 mechanical chain tensioner # 99 0458 053 M230 2 - Parts for oil by-pass mod For vertical valve (pressure relief valve) : - piston # 911 107 512 00 M260 - spring 86mm # 930 107 531 01 M260 - spring guide # 930 107 533 01 M100 - gasket # 900 123 106 30 M131 - plug with groove # 999 064 026 01 M260 For horizontal valve (safety valve) : - piston # 901 107 512 01 (with hole) - spring safety valve # 901 107 531 01 M260 - gasket # 900 123 106 30 M131 - plug with groove # 999 064 026 01 M260 |
Do not get the chain wheel support (a.k.a. idler arm) + spacer combination. The failures in the chain tensioner are related to the narrow arm binding on the shaft. There has been a good photo of this failure recently added to the forum http://forums.pelicanparts.com/6595201-post17.html
andy |
| All times are GMT -8. The time now is 06:52 PM. |
