-   -   Twin Plug Distributor Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/662960-twin-plug-distributor-question.html)
jcc911 03-04-2012 03:56 PM
Are any of you familiar with the Jarvis twin plug distributors what info can you provide?
How do you determine the advance?
Can these distributors be recurved?
Steve@Rennsport 03-04-2012 04:48 PM
Yessir, I am.
You need a distributor machine to determine advance and a selection of springs (GM) to change anything.
jcc911 03-04-2012 04:52 PM
Thanks Steve, what can you tell me about them?
Durability, availability of replacement parts, etc?
Would you be able to perform a recurve if required and how much? Thanks again.
Steve@Rennsport 03-04-2012 07:33 PM
These use GM HEI internals: the magnetic PU and advance mechanism, so parts are easily available. These use a Jaguar V12 cap with a custom rotor for the Porsche motor.
I can do it if you aren't in any kind of hurry. :) :)
Turbo_pro 03-05-2012 03:35 PM
Aaron @ Rennwerks should be at the top of the list for all your distributor needs even if you need it in a hurry.
rennwerks@hotmail.com
Rennwerks Inc.
Aaron Burnham
3968 Camino Ranchero
Camarillo, CA. 93012
805-240-6931
jcc911 03-08-2012 04:20 PM
Thanks again Steve. Will this distributor work with one MSD or will it require 2?
Thanks.
Steve@Rennsport 03-08-2012 08:38 PM
Thanks.
I always use two MSD's and two coils.
