Vertex alternator housing
I'm rebuilding a stock 3.2 and upon cleaning/inspecting, I notice the fan housing has a big crack in it.
Has anyone used one of the Vertex Aluminum alternator housings and fan? I received one today and without fitting it, the part does look good. Not quite die-cast smooth, but reasonable for a reproduction. I will be fitting it this weekend. After looking at the old housing, I'm wondering if I can TIG weld it with magnesium filler rod (AZ101). Anyone have any experience in repaired alternator housings? I should post a pic. http://forums.pelicanparts.com/uploa...1331265911.jpg http://forums.pelicanparts.com/uploa...1331265930.jpg |
If it were a fan housing from a four-cam carrera I'd say weld it in a shielding box.
It's not-- these are freely available in the classifieds. Maybe the quality of the Vertex part has improved, but the last one I saw would make a nice holder for a potted plan :) The fan spins at a multiple of engine RPM depending on pulley configuration so this is not an area to take any chances. |
A good friend of mine is in the process of making a billet AL version of the fan housing. He has the CAD done, and is working to find someone who can mill it. I've heard mixed reviews of the Vertex one, everything from its perfect to it's not worth a darn thing.
Thanks.
I'll post pics this weekend. It's aluminum, and it's cast. I'll know more when I go to fit it up, but frankly, it doesn't look bad. Btw, if these are so freely available 304065, send me one! |
I bought a vertex to replace a cracked shroud. Visually it's not as nice looking as oem but the alternator and fan fit perfectly. I didn't want to try to repair a 30+ year old part that would probably just crack again. Salesman at vertex told me this is version 3 and the fit is improved from earlier models. Little heavier since its aluminum instead of Mag.
I have one and it is rather crude but works.
The 3.2 alternator housings are prone to these cracks and are very hard to find without them. In the past few years I have seen close to a dozen of these and only found 1 or 2 that were crack free.
The 90 watt alternator in the 3.2 is longer and, as a result, the alternator mount face on the shroud got thinner making these units prone to cracks. |
I fitted the one I have and it seems to be just fine. Not Die-Cast magnesium, but looks to be of good quality none-the-less.
http://forums.pelicanparts.com/uploa...1331430811.jpg http://forums.pelicanparts.com/uploa...1331430831.jpg http://forums.pelicanparts.com/uploa...1331430856.jpg http://forums.pelicanparts.com/uploa...1331430981.jpg http://forums.pelicanparts.com/uploa...1331430999.jpg |
Any comments? I think the Vertex unit looks reasonable. Not polished chrome, but it seems like it will work and has no crack.
I got a vertex housing a year ago. I dropped my new valeo alt into it and looks like the thru bolts are not long enough. Not a problem in your case?
Did you also get the vertex fan? Is there a difference between oem and vertex? |
In my mind the questions is, did Vertex do anything in their design to eliminate the chronic cracking problem in these late alternator shrouds?
The alternator fitment in terms of bolt length might be the size/amperage of the alternator? They come in various sizes for different years to account for the current demand of the car. The later cars had more electrical stuff and thus the need to up the wattage of the alt.
Tom was gracious enough to share this chart he made in past posts. It tells a lot of the story. http://forums.pelicanparts.com/uploa...1331821188.jpg I'd be curious to know the dimensions of the Vertex housing to see how it compares to all the other variants Porsche made. Does Vertex sell just one size fits all or do they make different sizes? |
I like it. I only wish it had the part number instead of Vertex and the phone number. It is a bit heavier and from what I understand, the aluminum housing should be less crack prone than the magnesium housing. Heavier, but stronger. |
Well, we tried to weld the cracks in my fan housing last night. The mag corrosion was so deep the weld would not take. So I am off to buy a new vertex housing, I will post pictures when I get it.
http://forums.pelicanparts.com/uploa...1337483445.jpg
http://forums.pelicanparts.com/uploa...1337483476.jpg http://forums.pelicanparts.com/uploa...1337483525.jpg the quality was of an aluminum cast part. It seems to be pretty good quality. I had just a couple of issues with it but nothing major. pictures will follow of the problems. |
http://forums.pelicanparts.com/uploa...1337483663.jpg
http://forums.pelicanparts.com/uploa...1337483698.jpg the casting had slightly different positions for these two bolt holes at the top of the casting. No big deal really. I just drilled the shroud to match the housing. This is going on the 930 so I was worried about depth of housing, ect... The alternator was TIGHT going in...I mean tight! However it did go in...so It problaby will be a real ***** getting it out. But all in all, it was a good by, I would recommend it. next time I take it out, I will shave off the "Vertex" and the part number, make it smooth and powercoat it. Thanks for the help and info! http://forums.pelicanparts.com/uploa...1337484008.jpg |
I got a Vertex alternator mount not long after they started offering them. With the engine out a few months ago, I noted that the timing mark on the mount was 5 degrees ATDC. So I ran for those several years with the timing 5 degrees retarded from what I thought it was running.
| All times are GMT -8. The time now is 08:22 AM. |
