NEWFIE 69 911E's Avatar
What to expect? Rebuilding 80 3.0 Euro
Hi all,
Due to one broken head stud, I am preparing to rebuild the engine of my 1980 SC Euro (imported from Germany) this coming winter, and I'm wondering what to expect. Here are some details:
- 190K kilometers
- one broken head stud on #2. Broken stud that fell out measures 12.3 cm in length. Broken end was carbon-coated so it had broken some time ago
- engine never "opened"
- no oil leaks (usual seals and oil return tubes replaced)
- does not burn oil
- Tensioner and pop-off valve upgrades complete
- starts and runs perfectly, no smoke or strange noises
- driven approx 1,500 to 2,000 km per year
Some questions:
- Should I rebuild it now or drive it for the rest of this year? I discovered the broken head stud 3 years ago, and have driven approx 4,000 km since with no issues
- Checked some other posts; it appears that total stud length above base should = 13.5 cm. My broken stud is ~12.3 cm long, so I estimate that there is 1.2 cm left above the base. Is this enough to grab on to with vice-grips after heat?
- Can I get away with a top-end rebuild only? I don't drive it enough to justify spending big money. If so, what parts should I need? Is it likely that the heads will need work? Which studs should I order?
I've ordered Wayne's book, I've rebuilt engines before, and I have this great site and forum to help me, so I feel confident about doing this myself.
Any advice appreciated,
Thanks in advance,
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 08-05-2011, 02:52 AM
So let me get this straight; you've been driving it for 3 years with a broken stud, you don't rely on it for daily transportation, it doesn't leak or burn oil, it starts and runs perfectly...why bother? It takes a lot time, a lot of money (even if you DIY), and this motor sounds like it's in good shape overall. If you're just looking for a winter project then go for it, but otherwise I'd leave it be.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 08-05-2011, 06:53 AM
Yes, thanks, I understand your reasoning, and have been following the same train-of-thought for the last few years.
My main concern for wanting to rebuild is that I don't want to cause any damage to the head(s) that may cost more in the long-run. It seems that it should be OK as long as the head on #2 does not start leaking oil, or if I hear the tell-tale sound. I have read here that many people drive with one, or more, broken studs without issue.
1969 911E Coupe
Old 08-05-2011, 07:00 AM
You're going to do the heads anyway when you rebuild, so it's a wash. Even if you damage one, a used one is about $150.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 08-05-2011, 07:06 AM
Thanks - excellent advice and info
1969 911E Coupe
Old 08-05-2011, 07:55 AM
So, I think I will keep driving it this summer and fall, and then decide if I want to rebuild the engine over the winter (November to May up here).
One question remains for now:
Checked some other posts; it appears that total stud length above the base should = 13.5 cm. The broken stud that fell out is ~12.3 cm long, so I estimate that there is 1.2 cm left above the base. Is this enough to grab on to with vice-grips after heat?
1969 911E Coupe
Old 08-06-2011, 06:05 AM
I didn't have any luck with vice grips, but did have good success with heat and a stud puller tool like the one described in the book. I bought a Titan brand from Northern Tool for about $35. The Snap-On one is pretty expensive. 1cm should be enough for it to grab onto.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 08-06-2011, 06:42 PM
Brown747's Avatar
Did this a few days ago for a broken stud on #3.
Broken head stud defeated
1978 SC coupe #1834
Old 08-06-2011, 09:54 PM
TibetanT's Avatar
+1 ^^ per Brown747....that IS the ticket for getting these babies out.
Good luck with your project.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 08-06-2011, 11:47 PM
Excellent advice - thanks. Is this the stud puller you purchased:
Titan Stud Puller — 3/8in. Drive, Model# 16023 | Combination Wrenches | Northern Tool + Equipment
1969 911E Coupe
Old 08-07-2011, 06:09 AM
I agree with your reasoning; if you don't stress it to the limits, you can probably cruise along quite OK, but I would surely fix it.
It can damage both head as well as the cilinder.
Quite a few specialists I talked to recommend a full tear down for big-end and crank bearings past 180.000 km.
I had my engine taken apart last year at 220.000 km due to worn piston rings and valve guides (oil consumption). I hesitated between doing top-end only or the full package. I am glad I went in full. Quite a few big-end bearings were really at "2 minutes to twelve" as they were worn through the hardened bearing surface already. Crank was still fine, but close to potentially getting damaged from the worn bearings.
So in your case: I would enjoy the rides and often check for any additional snapped headstud. Then at some point fully take it apart !
Better a good one for a lot of bucks, than a bad one for little
Old 08-08-2011, 01:24 AM
Yes it is. It worked well.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 08-08-2011, 04:45 PM
flat6pilot's Avatar
That's the one I use too. Good results on exhaust and intake studs which are probably much easier to pull out [then head studs] but this thing has a great bite to it.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 08-08-2011, 05:45 PM
Air Medal or two
afterburn 549's Avatar
heat the H$LL out of the stud..maybe a couple cycles
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 08-08-2011, 06:31 PM
Thanks - just ordered this from Northern Tool and Equipment - preparing for my winter project
Thanks all for the advice. I'll be sure to post here when I start tearing the 3.0 down!
1969 911E Coupe
Old 08-09-2011, 07:59 AM
Update: Since I noted one broken head stud (a few years ago) I have been constantly listening for the "pop-pop" sound, and checking for new oil leaks.
Well, I still do not hear any "pop-pop", and the engine still runs great, but today I found a new oil leak on the cylinder with the broken stud:
Note my simple air injector plug.
My plan is to continue to drive the car for maybe 1,000 km total (unless I hear the "pop-pop") and then rebuild (top-end) over this winter.
Comments? Thanks,
1969 911E Coupe
Old 08-15-2011, 06:55 PM
Update: It is still winter where I live but I have not started the engine repair yet.
Of course, I'm hoping that the repair will be simple:
Replace all lower studs + gaskets and seals, machine one cylinder head (if sealing surface is damaged) and reassemble.
I'm hoping that I don't need to split the crankcase, but the oil pressure seems a little low. Suggestions?
1969 911E Coupe
Old 03-07-2012, 07:58 AM
Explain "a little low". At idle when warm it will show about a half bar and then 1 bar for each 1000 rpm (3 bar @ 3,000 rpm) is normal.
Tell it like it is or don't tell it at all.
Old 03-07-2012, 09:29 AM
Thanks - at idle it is about 1/2 bar, and then just under 1 bar for each 1,000 rpm.
see image below:
1969 911E Coupe
Old 03-07-2012, 09:49 AM
you cant machine one cylinder head, you have to do the group of 3 at least.
Bruce
Old 03-07-2012, 10:16 AM
