Question 89 C4 small oil leaks help
Dear All
I have two oil leaks and I like some help.
#1 The big problem is the oil leak around the cam shaft where the power steering connect too. I replaced the seals twice and it still leaks. It oil drop on the heat exchanger and can you smell the oil burning(small leak but smells)
Should I but a gasket sealer? what?
#2 small leaks around the bottom cylinder . I know that there a change in the machining of the cylinder base around 1991 but is there easy way to fix this with out modifying the cylinder (It a small leak at the base)
Andrew
Old 04-25-2012, 06:29 PM
