-   -   3.6 Head gaskets ?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/664577-3-6-head-gaskets.html)
Dick Shift 03-10-2012 09:37 AM
3.6 Head gaskets ??
Where to get head gaskets for a `92 3.6 ltr. engine. The CE rings supplied in a gasket and the one's everyone want's to sell me are to tall and not wide enought to fit tightly in the grove cut into the top of the cly. I understand the CE rings supplied/available are for the upgrade to the 89-90 3.6 engines that came with out any head gaskets/sealling material.
Origanly had a grafite like fiberous inbedded material as a seal in the shallow and much wider cly. to head sealing contact area.
Turbo_pro 03-10-2012 10:46 AM
Supertec has the graphite gaskets that fit the earlier cylinders.
The are listed in the parts search. 964 104 115 00
Porsche Parts Sales
Dick Shift 03-10-2012 01:51 PM
Parts ordered. Thanks Jim. or as we say in Hawaii, Mahalo Bra!
Henry Schmidt 03-13-2012 03:34 PM
Head gaskets will ship tomorrow.
Thanks guys
tkosier 03-14-2012 12:15 PM
I'm in the same situation. Saw your post and the response. I placed an order with Henry yesterday!
Thanks for all for posting.
Tom
Jupiter, fl
Dick Shift 04-25-2012 08:18 PM
FYI: From all my checking around I now believe the CE rings that come in the 964 gasket kits will work just fine. Despite the OD gap in the fit.
Having said that. I do believe the grafite like fibrous imbedded material type available from SUPERTEC PERFORMANCE are superior. Necessary? Over kill? At only $10 each good insurance I guess.
Henry Schmidt 04-26-2012 07:38 AM
The gaskets are an aluminum matrix sandwiched by multi-layered, heat resistant, graphite infused fibers.
Dick Shift 04-26-2012 09:41 AM
Re: aluminum matrix sandwiched by multi-layered, heat resistant, graphite infused fibers.
Sounds like lunch for Aliens.
