-   -   How to remove the valve spring disc 3.6L (http://forums.pelicanparts.com/911-engine-rebuilding-forum/668528-how-remove-valve-spring-disc-3-6l.html)
rothaus 03-29-2012 09:34 AM
I searched, however, I could not find anything on that. What's the best way to get the disc under the valve spring out on a 964 head. These are stuck and I don't want to destroy them.
Thanks for any help.
KTL 03-29-2012 12:58 PM
The valve spring seat/cup should be a very light slip fit into the head. Meaning, when the spring is removed from the valve, the cup should fall right out of the head if you turn it upside down.......
Alan L 03-29-2012 03:16 PM
If it is anything like a 911 head set up, they sometimes get a bit stuck with a surafce film of oil etc. try a magnetic pickup to persuade them to unstick. Works for me.
Alan
rothaus 03-29-2012 04:29 PM
I got them out from the first head.
http://airboxer.com/3600/spring_ring01.jpg
I used a copper bar. The only place is the higher side.
http://airboxer.com/3600/spring_ring02.jpg
http://airboxer.com/3600/spring_ring03.jpg
There was a lot of sealing compound in it.
http://airboxer.com/3600/spring_ring04.jpg
http://airboxer.com/3600/spring_ring05.jpg
The exhaust side is more recessed and I had to use a screwdriver. Looks like I need a few new ones.
http://airboxer.com/3600/spring_ring06.jpg
docrodg 03-29-2012 05:51 PM
That does not look like sealer... l;ooks like funky oil crud.
john walker's workshop 03-30-2012 06:49 PM
should be able to grab the lip and wiggle out any snug ones. never had your problem.
