-   -   CIS injection vacuum (http://forums.pelicanparts.com/911-engine-rebuilding-forum/669248-cis-injection-vacuum.html)
dirtydeeds85 04-02-2012 01:20 AM
Hello All,
I am in the final stages of putting my motor back together and I have 1 piece of vacuum hose which I'm not sure where it goes. I lost photos of the tear down.
Below is a pic of the vacuum hose in question. (not where the arrow is pointing, the one attached to the plastic air box.) Any help would be much appreciated.
Cheers.
http://forums.pelicanparts.com/uploa...1333354650.jpg
Flat6pac 04-02-2012 10:20 AM
It comes around the front of the engine from the black canister of the right wall. Recycles the gas fumes into the airbox.
Bruce
dirtydeeds85 04-03-2012 01:49 AM
Thanks Bruce,
That would be the charcoal canister no doubt. Which does not seem to be present on my car. So I guess it lead to nowhere when I pulled the motor out. Which would make sense as I seemed to have marked most other things properly.
Thanks again.
Cheers, Tim
