Pistons and cylinders in 3.0 sc case
Posted this over in 930 forum, haven't heard anything yet but was going to go turbo route on my 83 sc 3.0 and want to do 930 p's&c's I know the rods need rebushed for 23 mm wrist pin. What compression ratio do you think I will end up with is my main concern thanks.
The heads cc at about 89. With the reduced stroke, .75mm rod length difference (pin height issue) you will be lucky to get 6.37 to 1 compression. If you off set the wrist pin bushing by .030" you can get it back up to 6.70:1 |
Thanks Henry. Is that going to be to low? Is there another way to raise it up closer to 7:1 ?
I've done it many times. BTW: the 3.0 turbos were rated at 6.5:1. |
| All times are GMT -8. The time now is 09:27 AM. |
