-   -   Oil in number 2 cylinder (http://forums.pelicanparts.com/911-engine-rebuilding-forum/669611-oil-number-2-cylinder.html)
Eagledriver 04-03-2012 08:40 PM
I just built a new motor this winter for my race car. It's been working great for 2 weekends now, but a problem has come up. It started smoking out the left bank yesterday when I drove it to the gas station. I assumed I'd broken a ring or holed a piston. I pulled it apart and there is no apparent reason for the oil. The combustion chamber was wet with oil and the piston had about 50 percent less friction when I pulled it out that the other 2 pistons had. It could be that the less friction was from all the oil in the cylinder. The only anomaly I can find is the oil control ring is a little less tight in the bore than the other cylinders (none of them are very tight, they are just flimsy little rings).
At this point the only things I can think of are stuck rings that fixed themselves when I remove the piston, glazed cylinders or unseated rings (they don't look any different than the other cylinders and rings), or maybe a stuck open oil squirter.
Has anyone seen a stuck open oil squirter? does it cause that cylinder to oil up at low speed?
-Andy
Eagledriver 04-04-2012 06:32 PM
I found the issue. The expander for the oil control ring had a piece broken off. It was not expanding the oil control ring enough to get any kind of seal. I also found out from the shop that sold me the piston that I had installed the second ring upside down. This caused the second ring to pump oil into the combustion chamber.
-Andy
TibetanT 04-04-2012 06:36 PM
Andy:
Glad to hear you found the problem. Most would not even admit to installing a piston ring upside down; I admire your honesty!
?? Oil ring expander, is this the piece inside ring #3?
thanks
