-   -   Engine build.....one step closer! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/669641-engine-build-one-step-closer.html)
fred cook 04-04-2012 08:11 AM
I'm now one step closer to being ready to start my engine build. UPS dropped this off a couple of days ago! A 1000 lb capacity engine stand. I already had the Porsche engine mounting adapter (and the car). An appropriate capacity engine hoist and 3-4 minor engine tools are next.
http://forums.pelicanparts.com/uploa...1333552092.jpg
TibetanT 04-04-2012 06:42 PM
Love the color of your SC, Fred. Charcoal or black?
subscribingSmileWavy
fred cook 04-04-2012 07:03 PM
Color...........
My SC is the (original) black metallic color. It got a total, bare metal, glass out repaint last year.
flat6pilot 04-04-2012 07:56 PM
Hey Fred-
What's the reason for the rebuild? Just upgrading or did you tire it out?
fred cook 04-05-2012 05:44 AM
Reason..........
Originally Posted by flat6pilot (Post 6667708)
Hey Fred-
The engine in my SC has two broken head studs. After being in that condition for the
last 14 years (!) and finally developing a major oil leak I decided to do the rebuild. The finished product will be a 3.3 ltr SS with ported Carrera twin plug heads, 964 cams, and Electromotive XDi direct fire ignition. Exhaust will be SSI with a 2 in 1 out muffler and the fuel will flow in via a large port CIS intake box and runners. Cylinders are the LN Engineering 100mm slip fit versions and the pistons are 10.1:1 Mahle. All this should wake it up a bit!
