-   -   993 Valve Lifter Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/671236-993-valve-lifter-question.html)
pete911 04-12-2012 12:17 PM
I'm putting my 993 motor back together. I purchased new lifters. In the shop manual it says you are supposed to check the "slop" in the lifter after a valve job. You are supposed to use a lifter that has no oil in it. When I use the brand new lifters I don't have the required "slop". In fact on the exhaust side as I screw the rocker down with the cylinder at TDC (backside of the cam lobe) the valve actully opens a bit.
My question is does anyone know if the new INA lifters come preloaded with oil. If I use one of my old "collapsed" lifters I have the required play. If the new lifters are too tight will they loosen up after the engine is started?
Pete
syncroid 04-12-2012 12:38 PM
Pete
Yes and yes. Providing that you have the appropriate lash using a non pumped up lifter.
pete911 04-12-2012 12:46 PM
Thanks for the confirmation. It is kinda of freaky seeing the valve lift off of the seat when I know it should be closed.
Pete
syncroid 04-12-2012 01:00 PM
We have two sacrificial lifters that we use here in the shop just for measuring the lash. One for Turbo engines and one for the normals.
