9MM Con Rod Bolts
Trying to get some good info on the spec on the torque for my 1985 930 rod bolts, they are the 9mm style, should I use loctite, are what type of lube.
I have read and researched different methods. Whats the best?
I'm staying with the factory (new) fasteners. The original one's held up like 27 years, also I don't think I have taken the engine past 6K RPM's it's fast enough.
Thank's
Old 04-18-2012, 08:55 PM
No loctite of any type and torque them to the Factory specs.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-18-2012, 11:54 PM
Re
Steve,
My Tech spec book/pocket book only gives the torque on the 10mm bolts, do you know what the numbers are for the 9mm bolts are.
Thank you.
Old 04-19-2012, 06:40 AM
Sure:
1st stage: torque them to 11 lbs-ft
2nd stage: 1 lb-ft + 90 degrees
You'll need a torque-angle gauge to do this and both Snap-On and Stahlwille make good ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-19-2012, 10:01 AM
