thow out bearing help,...urgent...movie
i am trying to get my engine and trans back together and i am stuck with the throw out bearing,....
all i remember is when i unbolted my trans for the first time, the throw out bearing fell right out...
this is a 1980 930 3.3, stock pressure plate, and new throw out bearing, new clutch...
all same part numbers as what was there stock...
this can deff not be right, its loose and falling all around...
DSCN0257.AVI
The best amateur photography lives on Webshots
there is a groove that it looks like the fingers are supposed to sit in, but it would have to be pressed in from behind really hard it looks like??????
Old 04-17-2012, 04:26 AM
The throw out bearing rides on the guide tube on the tranny
It looks like you have it between the pressure plate and the clutch disk. The face of the bearing for the throw out bearing rides against the fingers of the pressure plate.
Old 04-17-2012, 05:02 AM
The TOB sits in the proper place. When you tighten the pressure plate it will cause the fingers to move and tighten to the TOB. The TOB is located with the tightening of the PP.
Bruce
Old 04-17-2012, 05:44 AM
Spiderman
Jesse16's Avatar
Of course, thats not right. Where is your thrust washer and spring washer. Those are what connect the bearing to the pressure plate fingers. Missing parts. Consult your Bentley.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 04-17-2012, 06:52 AM
Spiderman
Jesse16's Avatar
There are 5 or 6 parts depending on how you count them that work to lock the bearing to your pressure plate. They usually require a short "procedure" to get them apart, at least thats whats done with my 87 carrera.
Old 04-17-2012, 06:55 AM
Banned
Your are mistaken - this is NOT the case with the 930 set-up!
Old 04-17-2012, 07:23 AM
Spiderman
Jesse16's Avatar
Then my bad. Just looked to be a shadow on the fingers where other parts may have been. Geometry wise, wouldn't seem you could close the fingers (reduce the diameter) enough to establish a strong lateral grip to the bearing without other parts. I obviously have no knowledge of the 930 specific set-up. PP looks virtually same as mine. Good luck.
Old 04-17-2012, 07:37 AM
yes this is different, the 930 throw out bearing does not have those parts
Old 04-17-2012, 11:46 AM
SOLVED SOLVED SOLVED...
removed TOB and pressure plate, took it to porsche mechanic down the street to inspect. He said it is all correct, he said try it again and torque to 18.5ft lbs...
SUCCESS!, i am not sure if i had it aligned in the right groove or what the first time,...but were good to go now, its not going anywhere
Old 04-17-2012, 01:41 PM
Yup I was wrong.....I guess I forgot how mine came apart too.....
Old 04-17-2012, 04:14 PM
Must be nice to have a Porsche mechanic down the street!
Old 04-17-2012, 07:26 PM
