964 oil pump torque
Tore apart, cleaned and ready to reassemble, can not find a torque spec for the 4 housing studs. Did a search, did not find torque spec. Thanks.
Old 05-21-2012, 04:15 PM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
10 Nm = 7.375 ft-lbs = 88 inch pounds. I'd use new m6 nuts and lock washers, and loctite the threads. Also, the pump gears must all be reinstalled exactly in the same position and orientation as they came out. If you mixed them up, it's a good chance the pump will bind up and not rotate smoothly.
SOLD: '87 Carrera
Old 05-21-2012, 05:43 PM
Thanks.
Old 05-22-2012, 04:50 AM
