3.0 Rebuild
Rebuilding a 3.0 Looking for some helpful Info. The Proposed rebuild is as follows
Changing crank to 76mm stroke New Rods to support longer throw and compression JE pistons S Cams PMO Carbs 78/79 Heads with 39mm intake and 35mm exhaust Cylinders 3.0 Worried about added Compression ratio and Oil flow any help would be appreciated in the proposed engine setup, Good Idea, Neutral, or Bad Idea Billy |
| All times are GMT -8. The time now is 09:30 PM. |
