View Poll Results: Would you be willing to buy a stand or shirt to help bring this to market?
Yes 1 50.00%
No 1 50.00%
Voters: 2. This poll is closed
Ultra Deluxe Space Saving One-Man Engine Stand
Prototype phase 1 complete. The photos were taken while it was still *****in' hot from welding. I'm not done, there are some additions still in the engineering phase, but here we are thus far:
The goal, an atelier for VW/Porsche engine building that folds up to fit in a garage with everything else that typically occupies garages with a lift so that you don't have to pick up 200+ pound fully loaded engines and don't need to buy beer or upset significant others every time you do AND must work with a standard issue floor jack (no center leg).
Standard formation in use, lift down:
Standard formation in use, lift up:
Crank mount for Type 1, 36hp, and TIV (would need to get a hold of some other cranks/gland nuts to provide mounts for them):
Storage formation:
Storage formation from the back:
Also has all locking swivel casters so I can move it wherever I need it and not have to chase it down once I get it there. It will be powder coated, top quality components, etc. I still have a few features to add, and will definitely consider suggestions for additional features at this point.
I know cost is an obvious consideration. All effort will be made to keep cost to a minimum but NOT in exchange for quality or functionality. This will be a premium stand, not the EMPI crap or Harbor Freight nonsense (note: HF parts and pieces were used for the proof of concept model, but high quality parts will be sourced for actual production), so don't expect that sort of price. I'm anticipating a basic model with the stand/lift only, and a deluxe model that will have crank mounts, an oil pan, tool tray, etc. I won't know the final cost until I have spent time locating parts and fabrication services.
I am considering taking this stand to full production. Before I spend too much time or money tracking down fabrication shops, materials, or tooling, I want to see if it's worth it (I can't afford to dump a bunch of money into a hole). After this preliminary survey, I'll do the first run using Indiegogo.com to get preorders and will sell the first round at a discounted rate. That way there's none of the common scenario where a million people say they want to buy something, then no one steps up to the plate once they're built.
If successful and there is continued demand, I intend to use the proceeds to create and develop a business to design and manufacture some baddass VW/Porsche tools including a portable/collapsible car lift that I'm currently working on in the same spirit as the stand that will make dropping engines as easy as getting them on the stand and working on them.
The target market would be the German air cooled automotive enthusiast (VW or Porsche) who enjoys having the right tool for the job and is willing to spend a little extra on quality tools and parts. With access to a few other engines to mock up lifts/mounts it could be adapted to other cars (though obviously most applicable to those that don't require a crane lift for engine removal). It's not for the EMPI user, the Harbor Freight regular, or the garage sailor. It enables the enthusiast to be self-sufficient in an age when the few air cooled shops that remain are closing their doors one by one and few people know or care how to turn a wrench to properly maintain an automobile. This combined with the car lift I have planned will enable these individuals to essentially have their own fully functional shop without significant compromise, while still being able to keep two cars in their two car garage.
Prior to selling my bus a few months ago, when I would do any work on the engine (just about anything more than valves and oil), I preferred to remove it (like they used to at the dealerships) so I could have full unhindered access and line of sight to everything I needed. It took me all of 15 minutes solo in my driveway and with some jazz playing on the radio was a very fun and relaxing experience. It always ceased being fun and relaxing when I was trying to work on my engine balanced on my jack or jack stands. Once I got this stand built, I was looking for any and every excuse to modify my engine. This was my daily driver, so I couldn't afford to mess up or have any unplanned downtime.
The basic stand (stand and lift only, not the extras like crank mounts, tool trays, oil pans, etc.) will likely be able to come in under the $200 mark. The deluxe stand will probably come in under $300. These are very loose ballpark estimates, and subject to change.
In addition to the engine stand, to raise additional funds to make the idea of reality I also do some graphic design and have a few pretty awesome VW/Porsche themed t-shirts (more to come including bus, 356, and 911/912 themed shirts):
A groovy engine graphic I did for my car club T-shirts
A design study in the generational changes in the Karmann Ghia across years and markets
Old 07-25-2012, 01:52 PM
AlfonsoR's Avatar
I wouldn't buy it just because I prefer dedicated tools, but I think it's a good idea and I believe there are/would be some folks interested.
One thing I noticed is there doesn't seem to be a way to move the engine latterly once it's on the hydraulic fork. This might be a problem if the engine is not sufficiently centered so that you can mate it to the mounting flange. I think some people might be tempted to try to push the engine into place instead of lowering it back down and trying to center it and bring it back up.
Anyway, good luck, I hope it goes well.
"Simplicity is supreme excellence" - James Watt
Old 07-25-2012, 08:18 PM
You don't use the lift to pull the engine, you have to use a regular floor jack. Once the engine is pulled, you roll it up to the stand and at least one of the two will be free to move around without the weight of the engine if you weren't able to center it as you roll up.
Old 07-25-2012, 08:39 PM
