1977 3.0 motor trans. rebuild
I have a 1977 careers targa 3.0. Motor needs complete rebuild and want upgrades/modifications for oiling ,timing chain, head studs etc. And d SSI exhaust. Was given estimate for$30,000. Seems like ripoff. Opinions please. Also price for transmission rebuild
Carrera Targa 3.0. Sorry
It's my feeling that a vendor has the right to charge whatever they deem appropriate but that number seems high.
I would call Henry @ Supertec. Those types of engines are what they do. 760-728-3062 supertec1@earthlink.net |
Thanks for the reply. I thought was out of line and now they want $2,500 for checking it out. WTF. There not installing new pistons or cylinders but are quoting all the upgrades and SSI exhaust.
I called (3) other shops and they all tell me around $18,000 including rebuilding feul reg. and painting all pans, parts as original so all I have to do is bolt it in, plug it in, add oil and fire up. The other (3) shops all came in within $1,000-$1,200 of each other so seems like the first guy trying to really stick it to me. In addition the first guy I talked to tells me labor hours is around 115 hours. Everyone else about 60 hours. I guess it was my fault for not asking what the cost of checking things out was going to be but Holly Crap Batman!! But I didn't think it was going to be that far out of line. |
$30k and no new P&Cs. wow! even $18K sounds high, especially if they don't do the install and finish up the job. keep looking.
Just talked to another shop. Told me $15-$18,000. Doing ALL performance. I feel very comfortable with that. pAINTING PARTS ETC.
Sorry for spelling error. Doing all performance upgrades and painting pans, fan housing etc.
what are you going to get exactly, for $15-18K? new P&Cs, new oil pump, new intermediate shaft, new rockers and shafts, chains, sprockets, etc? hopefully.
Ok here was the estimate:
Rebuild 3.0 Carrera engine complete Replace expoxy on timing covers Rebuild cylinder heads complete Set valve height and spring pressures Remove all cylinder head studs and replace with Racewear head stud/nut kit Replace connecting rod hardware with Racewear hardware kits Polish rocker shafts and rockers Remove all alum. oil port plugs in crank and engine block for cleaning oil passages and install new. Resurface intake valve covers, oil strainer cover,intermediate shaft cover, intake manifold bases. Acid clean oil cooler and pressure test Refinish alum. altrnator fan and housing. Strip and refinish engine tins Magnaflux/polish cranksahft Fly-cut cylinder heads. Rebuild transmission complete with no major hard parts needed to be replaced such as gear sets or main bearings. Parts: Intermediate shaft (used) Intermediate shaft bearing set. Main bearing set Rod bearing set Engine gasket set - Top and Bottom end Valve cover service kit Racewear head stud kit Racewear rod bolt set Oil return tubes Oil filter Racing timing chain and ramp Carrera Timing chain update kit Update Timing chain idler/sprocket Left and right Oil pressure switch Oil temp switch/injection (used) Alternator belt New intake valves New exhaust valves Valve guide HD Rocker shaft seal kit Rocker shaft and arm (used) Piston ring set Valve spring kit Cam tower oil fitting kit Exhaust valve cover/Turbo Oil pump lock tab Fuel injectors Rebuild fuel distributor Rebuild fuel pressure regulator Rebuild ignition distributor Throttle bellcrank bushings Cold start injector Breather hose crank tooil tank Air filter straps (rubber) CIS Injection boot Intake manifold boot Heater hose Oil lines cooler to tank Ignition cap, rotor, coil Stainless cover ignition wires Spark plugs, fuel filter, air filter Sach Power clutch/ alum. pressure plate and pilot bearing Flywheel and pressure plate bolts SSI header and heater box set Oil lines for SSI Oe type muffler Stainless strap |
As you can see NO New Cylinders or Pistons. Please, opinions that I can trust are welcome.
Oh by the way. This exact estimate was $28,000. I took the motor and trans. out as a unit and gave to the shop to evaluate. I since have spoke to a few other shops and they are telling me numbers around $18,000. I don't who to trust. I'm on East Coast-PA
just did a quick pricing for you. sorry about the sideways pic. seems $18K is in the ball park, w/P&Cs, which may vary a bit in price, depending on who sells them.
http://forums.pelicanparts.com/uploa...1335633073.jpg |
Didn't see fuel pressure reg etc rebuild, stripping painting tins, turbo valve cover upgrade, oil modification upgrade etc. Is the the $1,000 misc?
I will call you |
painting tin is in the labor part. valve covers in the misc crap part. you may not even need the rebuilt WUR and fuel distributor. you could replace even more if necessary, like rocker shafts (which you would not polish), oil pump, complete intermediate shaft, if they don't pass inspection after disassembly.
Can we be safe to say that even if we were replacing oil pump, intermediate shaft and rocker shafts we would be no higher than $20,000?
| All times are GMT -8. The time now is 11:50 PM. |
