SLR
964 cams fitting to a 3.2
Hi all
1st time on this site, so if I goose it up a bit forgive me. I have a 1985 Carrera in way good nick, the only thing i have changed was to fit a Steve wong chip, ye ha. but I'm looking at fitting 964 cams, but have read so many story storys, Has any one here bone that ? and what is the benifits ?. I don't want to flaff about to much , the money thing, I want to fit 8x16's on the rear. as well thanks Steve |
964 cams give more mid-range power; one can feel & measure it.
![]() Your chip will need to be remapped of course.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
You do not need actual 964 cams. I had my 1979 SC cams re-ground to 964 profile, I assume your Carrera Cams can also be reground. I've also heard that a good header / exhaust will give you the best gains on a Carrera than the chip.
Call 911
I fitted 964 camshafts to my '88 Carrera 3.2L engine when doing a top-end overhaul. Found a nice set from a reputable eBay seller and paid $450. The cams provide a noticeable performance increase that you can feel...especially above 3800 rpm when the engine really wakes up.
These camshafts have increased duration on both exhaust and intake valve events, plus slightly increased lift. Idle quality is still good, but a little more "lumpy" than the stock 3.2 cams. The only modification required is to remove the power steering extension stub off of the right-hand camshaft, as shown. My local automotive machine shop did this for $5. ![]()
Dave Kirk My Porsche restoreth my soul. |
The re-grind of my SC cams cost me under US$300
Call 911
One thing that I forgot to mention is that I have a Steve Wong chip that was installed prior to the camshaft swap. I did not have the chip reprogrammed, and find no reason to, due to the way the engine runs throughout the operational speed/load range. Cold and hot starts are perfect, no signs of running rich anywhere, good throttle response, and nice manners. The only change I notice is fuel mileage - before the cam swap I could get 27 mpg (steady state cruising @ 70 mph) which has now dropped to around 25.5 mpg - not a big hit considering the performance increase.
Hi Number1_dog
Where do you have re-grind service, can you recommend one? Many thanks! |
I had my 1979 911SC cams reground by John Dougherty back in 2009.
John@drcamshafts.com or tel# 530-672-2286. He is in Shingle Springs, Ca. I included a postal money order for full payment and had them back in my hands within a week. I didn't listen to the people complaining about John and he came through. dog |
How much power would one expect from doing this?
John Flesburg 1974 914-6 3.2 - Street Car (Silver) 1974 914-6 3.2 - Track Car (Red) 1983 911 Turbo - Street Car (White) 1973 914 - Unit Body (to be a track car) (Primer/Steel) |
a.k.a. G-man
Are there any benefits to still reprogramming the chip?? Engine runs great as is. Would a remap improve it even more, give more hp?
Geronimo 32C Member #41 1986 911 3.2 Carrera (not stock) 1974 911 2.7 9114102230 SOLD |
Anybody have an answer for questions post #9 and #10?
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
French Import
Will the cam regrind cause the car to no longer pass the California smog test?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 05 BMW K1200 LT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Camgrinder says the 964 grind in a 3.2 will pass CA smog
French Import
Thanks TTO! Contemplating the modification as the engine is out.
gruppe f
My '87 3.2 with a Steve Wong chip and 964-grind cams easily passed smog last December, even with the infamous "brown wire" disconnected.
mike
Mike Hinton '87 Carrera Granite Green '72 911-T Aubergine '74 914 1.8 Marathon Blue '59 356A Coupe (long gone) |
I have Camgrinder reground 3.2 cams and stock chip. Pass CA smog easily. Car 89.
1989 3.2 coupe, DIY top end at 77k, now 103k 1999 BMW 328i, 180k - sons car 2011 Honda Civic, 10k - other sons car 2012 Lexus ct200h, 12k - wife's car, 8 year warranty 1995 Suburban - 203k miles, my other car, love it, easy to repair |
I think remapping would be beneficial when changing cams.
Early S member #1969 1987 Porsche Carrera 3.2 1986 BMW E30 M3 |
I have the Steve Wong chip on my stock 3.2 Carrera which I am about to re do the top end on.
I'm wondering If I used a 964 profile cam and fitted the higher compression euro P&C's would that effectively negate the use of the chip ? I have a dansk Pre muf and Dansk sport muf on the car. It strikes me the only sluggish area would be in the 1-2k RPM range. But would the increased torque make up for it ? |
Are you planning to turn this into a diesel engine? I think most would be happy with only a power issue in the 1-2K rpm range. ![]() From many owner comments, the correct Wong chip will only enhance that which you plan to add. Sherwood |
