-   -   964 Cam Tensioners - do they fail? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/677460-964-cam-tensioners-do-they-fail.html)
JeremyD 05-12-2012 06:03 PM
How common is it for a 964 cam tensioner to fail? Have about 1800 miles on my 964 engine that received a major top end (P & C's) Cams, Heads done... When I went to restart after a first session at DE today - had a rattle that sounded like a chain tensioner.
did not replace the tensioners when the engine was out.
BTW - no missed shift - no over rev - - no smoke - car runs - just sounds like chains dragging on a garbage can
b930 05-21-2012 03:28 AM
Hi,
Did you find out if it was the tensioners?
Flat6pac 05-21-2012 04:14 AM
I have seen them fail and note, there is a right and a left tensioner for proper installation.
Bruce
b930 05-21-2012 04:50 AM
Bruce, I thought both left and right carried the same part number?? I hope so because I just ordered 2!
JeremyD 05-21-2012 04:58 AM
Left and right with different part numbers.
Flat6pac 05-21-2012 06:28 PM
the left side has a longer nipple on it, visually longer.
Bruce
