-   -   Heads height 2.0, 2.2 - 2.7 ... ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/677719-heads-height-2-0-2-2-2-7-a.html)
964-RSR 05-13-2012 11:27 PM
Hello,
I can't find the original height of heads for a 2.0L or 2.2 - 2.7 and the lowest height suggested by the factory.
I have measured my 2.0 heads and found 87 mm between the gaskets surfaces.
My 2.4 heads are 87 mm too but I have to substract the height groove where the O ring gasket goes (- 2.5mm) => 84.5 mm
I can't find why there is a difference between the height heads ! :confused:
I don't have measured the height of cylinders 2.0 and 2.2 - 2.7. May be there is a difference ??
Thanks for your help.
