porsche 962 head-cylinder
Hi,
does anybody know the price of a single 962 head-cylinder ? |
Forced Induction Junkie
I believe the 962 cylinder heads(water cooled) are bank based and can not be separated.
See attached thread. Rebuilding a 962 motor
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
o.k. but nobody will buy the complete bank if he have only one broken head. There must be an interest for single parts, because it's no problem to use a single one when the size is o.k.
Sorry, what did you mean with 'bank based' (head+cylinder=one part, that's clear) or that you can only buy the cyl. 1-3 or 4-6 ?
bobby,
I meant to say cylinders 1 through 3 has a single head and cylinders 4 through 6 has a single head. Once you start getting into water cooled engines, most consider the left or the right side as a single unit since the units are cast as one piece. The cylinders are probably press fit into the heads.
sorry, but that's not right. The 962 Engine has single heads. The are together with the cylinder(water cooled) as one part. They are laser-welded. And I would like to know the price for such a cylinder-head-unit.
Doesn't want/need a 3.6L
Bobby,
I don't know where much of the information above was sourced from, but here is the part number for a 95mm head/cylinder: 935 104 020 02 I have no idea what a single used unit may sell for, but here in the USA we have two good sources for new units (albeit not inexpensive): Eric Bloss from Porsche Motorsport and Neil Harvey from Performance Developments. Neil makes his own and considers them an "upgrade" over the Porsche part. He can be reached at http://www.performancedevelopments.com and he may have some "take-offs" that are in good condition. It's worth a fax or email. Eric probably has plenty of used units laying around, so he may be a good source for a used unit as well if you can't find one in Germany. He can be reached at http://content3.eu.porsche.com/prod/motorsport/sales.nsf/usaenglish/pmna_business_infopmna_personell_prjectm BTW, his hairline has receded further. Ralph |
Oops! Sorry.
Looking at the pics from helidoc, they look one piece.
ok, what is then this for a head-cylinder-unit ?
Author of "101 Projects"
I have one of the single units on my desk here at work = very cool. I think that the single one may be a 956 unit and the bank of three a late-model 962 unit? They are very similar...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
An exception is the 959, which has a head gasket between the head and cylinder. Hopefully this puts any confusion above to rest. Ralph |
I think that the head pictured in this post might be an earlier version of the water cooled head only engine. Porsche supposedly made 2 water cooled engines for the 962, the earlier version I think only the head was H2O cooled and in the later versions like mine both the head and cylinder walls were cooled. If I am not mistaken, I think the 956 was an air cooled motor. I think the later head sections are "cold welded" together and can be bought as separate cylinders. I have been told figures in the $9000+ range if you can find one.
Hi,
that are really good news for me. Thank you for the information. I've got one of these cylinder-head-units. Do you know some people who are interested in such a unit ? |
Re: porsche 962 head-cylinder
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
that's what I really want to know !!!!!!!!!!!!
Doc, weren't the 956 a 4 valve motor? If so watercooled heads were mandatory.
Ralph, What is in question is individual heads versus 1 head for the whole bank. Do you have any info on that? Bobby, find me some rods for that 956 will ya?
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Boy, this thread sure has gotten confusing! I thought that I was clear in my previous comments but I guess not. I will try to simplify and better explain myself
The 956 used a 2.8L 4-cam, 4-valve, twin-turbo motor that was mechanically injected using Kugelfischer injection. It had air-cooled cylinders and water-cooled heads. This motor never ran in IMSA but was used in Group C in Europe. You can consider this motor a precursor to the later 962C motor or an evolution of the earlier 935 motor, whichever floats your boat. The 962 that was raced in IMSA in the mid/late '80's was a completely air-cooled, flat-fan, twin-plug, LARGE single-turbo motor that is what all of our air-cooled motors aspire to be when they grow up (well, mine at least ) This motor was built in 3.0L and 3.2L displacements and used Motronic injection (albeit much more advanced than the street car version).The 962C from the late '80's/early 90's was the final engine version and was also built in either 3.0L or 3.2L displacement. I guess you could consider this an evolution of the earlier 956 motor. It was similar to the 956 engine, in that it was a 4-cam, 4-valve, twin-turbo motor BUT a couple of obvious differences were that it had water-cooled cylinders and heads and used a further updated version of Motronic. Whether it be a 956 or 962C motor, the cylinders/heads were all 1-piece units and were removed/installed individually. There was never a "single" head for one bank. I suppose it may appear that way to some when the water jackets are fitted on the motor, but when the water jackets are removed the cylinders/heads do come off individually. Helidoc just did this, he should be able to confirm. Is that a bit more clear or did I further confuse people? Ralph EDIT: The very first 962 air-cooled IMSA engines were single plug and had not yet been twin-plugged, not important in this discussion but something to mention before someone calls me out on it.
Thanks Ralph, that set me right. Cheers!
Hilbilly Deluxe
Sorry, sometimes I just assume that people see what I see. To answer the question above, the cylinder/head pictured is a water/water unit from a 962C engine.
If it were an air/water 956 unit, the cylinder would have cooling fins similar to what our air-cooled 911 motors have. The "bare" cylinder without fins is a dead giveaway for a water/water piece. Ralph |
