-   -   85 starting issue (http://forums.pelicanparts.com/911-engine-rebuilding-forum/678204-85-starting-issue.html)
bluemane500 05-16-2012 05:33 AM
85 starting issue
hey guys,, im not usually here but i have a problem and maybe someone can help me,,,my 85 turns over well but will not start,,,if i just tap the key it will fire and run,, i found this by accident when checking the power at the fuse box for the fuel pump,,, so i changed the ignition switch and the isuue is the same,, any ideas thanx
http://forums.pelicanparts.com/uploa...1337171566.jpg
