-   -   Which GT3 Crank for 993 Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/678477-gt3-crank-993-engine-rebuild.html)
Trophy 05-17-2012 02:12 PM
So I have been looking at GT3 cranks and oil pumps to create a bullet proof bottom end on my 993 engine rebuild, however I have noticed a number of different part numbers for GT3 cranks.
Does anyone know the differences between the following cranks and what if any issues could be faced with each?
996 102 021 95 - M97-77
996 102 021 94 - M97-76
996 102 021 92 - M96-79
Thanks in advance...
MBruns 05-17-2012 03:03 PM
Gt3
The newest p/n is 996 102 021 95, the others superceded to this ( as of 2 weeks ago) cost was 1716.79
Mike Bruns JBRacing.com
Trophy 05-17-2012 03:14 PM
Thanks Mike, As I understand the only thing i need to replace (other than different rods or pistons) is a different pulley, it that how you understand it?
MBruns 05-17-2012 07:06 PM
Gt3
Steven, the GT3 cranks are pinned on the opposite side and have a smaller pin, the stock pulley is a serpentine, perhaps Clewett has an early style pulley for this conversion, the pankl Ti rods are 3.0 SC dimension and the GT3 rod bearings are a good choice, have some pistons made and enjoy !
Mike Bruns
Trophy 05-17-2012 07:57 PM
Thanks Mike, really appreciate the advice.
I have found that rothsport make a pulley for this use. I have a set of Pankl Ti rods already, so will just get a set of pistons made and should be good to go..... Thanks for the advice in the GT3 rod bearings, was going to be my next question.
Regards,
MBruns 05-18-2012 04:52 AM
pulley
Very good, Jeff makes some very nice stuff
Mike
wprater 03-01-2022 01:57 PM
Looks like the latest part no. is now 996.102.021.96
mikedsilva 03-08-2022 03:26 AM
I wonder how the price compares now, to back then?
stanglife 03-08-2022 01:34 PM
A lot more. Even the .95 says its been replaced - that one could be had $1800us - new one closer to $3k.
JoeMag 03-09-2022 03:42 PM
…how about the pankel Ti rods capability? What piston weight can they hold at what max rpm?
Nizer 08-21-2022 09:35 AM
Are you targeting 3.8L or 4.0L with your rebuild?
