82 911 valve clearance
Just timed left side cam to 1.52mm. Checked intake clearance and have 1.1 mm checked exhaust clearance and have 2.5 mm is the intake ok or should I try to retard the cam for more clearance. Have read that 1mm is ok. Just wanted another opinion before I time right side cam. Thanks in advance for any advice. This is a stock rebuild 930/16 CIS motor with the only change being .005 taken off of the heads to clean up after broken head studs.
Old 06-26-2012, 06:52 PM
1.1 is enough on the intake side. How did you measure it? If you were at TDC you might not have an accurate measurement.
-Andy
Old 06-27-2012, 05:12 PM
I started at TDC and rotated ATDC by 5deg each time until i cleared piston.
This was measured using a dial indicator with no rocker clearance.
I know that it is close but i thought that the CIS motors had more clearance than that from the factory? The only minimum clearance that i could find was in Waynes book being 1.5mm but have herd that 1mm is ok.
Old 06-27-2012, 07:27 PM
