Re-Torque 81SC
I know this topic has been beat to death in this forum and elsewhere. But here it is again.
Just had a top end rebuild done and Racewear head studs installed. I have searched this site and the advice seems to be all over the place on re-torquing these studs. Back off and torque, just check the existing torque without backing off first... So, in an attempt to clear things up, I called Racewear today and was told that (unlike water cooled engines) because air cooled 3L 911 engines like my 81SC use metallic gaskets the engine assembly is essentially "metal to metal". Because of this I was told re-torquing was not necessary. I told the Racewear guy that I intended to take the valve covers off anyway to reset the valves, "so why not re-torque while its apart?" He said that was fine if I wanted to do it, but recommended that I back off the nuts one at a time and re-torque to 24ft/lbs. One important thing I noted was that he said his re-torquing procedure only applied to Racewear studs. He said factory studs use "break-away torque" and the procedure for them is different. Thoughts? |
83 911 Production Cab #10
To re-torque you have to back off first and then torque to the proper value.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Any other opinions out there? |
If youre going to back off the torque you really need to relube the threads because a dry torque is a false torque.
Bruce |
Generally the idea is to check that none of the nuts has become loose. I don't even use a torque wrench sometimes. If they are loose it will be very apparent when you start to tighten them.
-Andy
72 Carrera RS replica, Spec 911 racer |
Banned
I am in complete agreement with Bruce, and the Racewear "tech's" advice seems silly to me. I too have Racewear studs, though in a turbo engine, and I simply set my digital torque wrench to what I want and then turn until I hear the "beep". The last time I did this, I think about three of the nuts tightened slightly (though was hard to tell) . . .
Given the Racewear guy didn't even think the torque needed to be checked, I think I will decide to Flat6's method. I don't, in general, think its wise to dismiss the advice of the manufacturer. |
