-   -   Does this sound like rod knock? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/684493-does-sound-like-rod-knock.html)
Aurel 06-24-2012 09:42 AM
Well, actually it does not run anymore...but that is ignition related. I disconnected the coil to test the compression on that cylinder 3. I got 120 psi, which I think is ok considering the altitude over 5000 feet, the cr of 8.5:1 and the fact I measured it cold. When I reconnected the coil, I got no spark, no more ignition at all. Weird.
Aurel 06-25-2012 06:44 PM
Had I read a little more before doing my compression test, I would have saved myself a $89 coil...
hopefully I did not burn the CDI box too.
http://forums.pelicanparts.com/uploa...1138414059.jpg
911 tweaks 06-26-2012 06:45 AM
correct posting aurel...i always disconnect the 2 wires that have sm nuts holding them to the top of the coil so as to not damage coil, cdi(if applicable type car) and I unplug the coil wire out of the center top of the dizzy just to be safe...
P911S 05-05-2019 06:38 PM
Did you ever figure out what the issue was? Rod bearing, lifter, or tensioner?
Aurel 09-18-2019 04:06 PM
Yeah, Rod bearings. I rebuilt the whole bottom end back then...
Solamar 09-18-2019 07:41 PM
Was there any metal flake in the oil?
I would think with that amount of rod knock you would find some flake in the oil.
