(man/dude)
Jonny042's Avatar
Camshafts in housings - how much resistance?
Hello all,
When checking the fit of my new cams in the bare housings there is a slight resistance to them turning. I can turn them by grabbing the snout with my fingers and thumb and giving it a twist, but there is slight friction, and the cam doesn't "spin" freely in the housing due to some slight drag.
If I had to guess I'd say there is 1/4 foot-pounds of torque required to get them to spin. It's very slight, but is accompanied by a bit of a rubbing noise.
I'm telling myself that obviously the cam journals aren't subjected to the huge loads a conrod big end or crank sees, that it spins at half the speed, and that the old cams fit/turn/feel the same.
I did a very quick check of the oil clearance and it's in the .0025" range. Pretty much what you'd expect.
Maybe the result of a few nicks in the bare aluminum bores from taking the cams in and out?
EDIT/PS - I did try the cams in the housings on the bench before bolting them to the motor. No difference when installed/torqued to the heads.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 09-18-2019, 07:41 PM
Were the cam journals were oiled on installation?
Use v-blocks and a dial indicator to measure the runout on the cams to see if they're straight.
Old 09-19-2019, 04:16 AM
Targa_PB_78_SC
mike sampsel's Avatar
FWIW:
I decided if I could turn my cam easily with a finger and gimpy thumb I was good. Cams were lubed with assembly lube prior to insertion. There is still some friction with the lube and inertia with the cam mass, it won’t be a perpetual motion machine once you move it. I could hear a bit of noise too if I recall correctly, the joy of cam journals with 115k miles I expect.
If you have new cams, I suspect they are straight.
Old 09-19-2019, 05:01 AM
If you can turn them all the around with your fingers then you’re good
Tony
Old 09-19-2019, 09:45 AM
(man/dude)
Jonny042's Avatar
Originally Posted by mike sampsel View Post
FWIW:
Haha I'm using my gimpy thumb too! My physiotherapist measures the strength and says I'm at least 100% of my left hand but it's still limited in certain directions.
Old 09-20-2019, 07:47 AM
Once you start with oil pressure and flow the resistance becomes insignificant
Bruce
Old 09-20-2019, 11:57 AM
