neilca's Avatar
Valve guide interferance
I had to weld up one of my exhaust ports since I was a bit over zealous with the porting tool. Now I need to install a new valve guide. The hole in the head measues 0.505" the valve guide is 0.515" . I think 0.010" of interferance is too much, just a gut feel. Anyone have an idea on what kind of interferance should be used?
Thanks,
neilca
Old 07-10-2012, 02:27 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Sounds a bit big to me too.
Maybe .005" is closer....you can spin the guide using a drill and sand the OD with paper to reduce it.
Bob
Bob Hutson
Old 07-10-2012, 03:57 PM
neilca's Avatar
I was thinking of using a 13mm reamer (0.5115") and clean up the hole. That would give me 0.0035" interferance. I have a cylinder head jig and a large mill so I can maintain the vector of the hole. What do you think Bob?
Old 07-10-2012, 04:31 PM
abit off center
cgarr's Avatar
2 to 3 thou is good. You can get oversize guides and turn them down to the correct interference. Use lube to avoid gulling.
______________________
Craig
G2Performance
Old 07-10-2012, 05:27 PM
HawgRyder's Avatar
As Craig suggests...you are in the ball park for the sizes.
And by all means...heat the head (wife's oven?....LOL) before pushing in guide.
Bob
Bob Hutson
Old 07-10-2012, 07:12 PM
neilca's Avatar
Craig,
Good call on the lube, what kind would you suggest, old oil, anti seize etc
Bob,
I usually freeze the guide with dry ice. My Mother's oven had been used inthe past to fit bearings into motorcycle cases. I am not sure I would chance that with my Wife's oven. LOL..then again if she were off shopping.....
Old 07-11-2012, 03:06 AM
Air Medal or two
afterburn 549's Avatar
dont for get to check your head for sq and flat after the welding.....
Yes to the dry ice Listen to them scream !
yes to oven heat cycle a couple times B4 doing valve job after the guide install
(incase they move after heating up)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 07-11-2012, 09:33 AM
abit off center
cgarr's Avatar
Just a good penetration oil in the bore and the guide works well.
Craig
G2Performance
Old 07-11-2012, 09:57 AM
